do i need new injectors or a new chip?
Old Feb 13, 2005 | 09:05 PM
leonpiper69's Avatar
Car: 91 mustang
Engine: ls1
Axle/Gears: 3.55 8.8
im dropping a 350 into my s-10. and i have a 305 tpi setup. this is not a sick motor, just a stock rebuild. i'de be lucky if i pushed 300 horse out of it. i was just wondering that if the only thing diff is displacement, then the maf is gonna see more air and hold the injectors open a little longer to compensate (essentially as if the 305 it thinks its on is just breathing a little better).
do i need to replace my 305 chip with a 350 chip? and do i really need bigger injectors on a mild motor?
19lbs per hour x 2 x8 injectors multipled by 80% duty cycle = 243hp. oops. i thought that would come out higher. i guess i do need bigger injectors, but what about the chip and what year injectors interchang? a guy offered me 24 lbs off an lt1 for 40 bucks .
Old Feb 13, 2005 | 09:46 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
The 24#/hr injectors are OK for your 350, IF they are is excellent condition. Also, you should get a 350 chip and an AFPR to help getting things dialed in.
Old Feb 13, 2005 | 09:51 PM
Car: 91 mustang
Engine: ls1
whats an afpr?
Old Feb 13, 2005 | 10:49 PM
91 z28 350's Avatar
Car: 91 Z28
adjustable fuel pressure regulator
Old Feb 14, 2005 | 07:28 PM
Car: 91 mustang
Engine: ls1
oh! is that also known as an fmu
Old Feb 15, 2005 | 08:45 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
No. An FMU can control fuel rate at every rpm, the afpr will keep a constant pressure behind the injectors.
To get it running properly, get a 350 chip and change the injector constants to match your injectors. You would only need to change one number in the chip. Also, to get full potential from the engine, you should get into tuning, check out the DYI Prom board.
Old Feb 15, 2005 | 08:55 PM
Car: 91 mustang
Engine: ls1
thanks. looks like i have some readin to do.
Old Feb 15, 2005 | 10:18 PM
Vader's Avatar
That's O.K. (It may be the kerosene vapors.) that's the sole purpose of this site.
Old Feb 16, 2005 | 07:03 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
FWIW...24#/hr injectors are plenty big enough for a 350. Just as an example I ran 24#/hr injectors on a 406 with 58psi and they kept up fine. Just get yourself a AFPR and you will be fine for that motor.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
