distributer for 350 TPI
Old Feb 18, 2005 | 01:57 AM
LKJR's Avatar
Well I bought a TPI setup from a guy at the beginning of my learning curve. Well pretty much all that is good to me is the plenum, intake and runners.
the dissy I got is a points style
So I"m looking for suggestions on a distributer.
I'ts going in a 4wd truck for rock crawling.
Old Feb 18, 2005 | 10:41 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Well, you'll definately need one that can be controlled by the ECM for spark timing... I'd recommend an 87-up small-cap HEI with the divorced ignition coil and the 8-pin module (the one with the two weatherpack connectors on the outside)...
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
