super ram
Old Feb 20, 2005 | 09:29 PM
purplebird's Avatar
Car: 1992 firdbird formula
Engine: 5.7 tpi
super ram
I wss wondering where is the best palce to but the super ram. also does anyone have any tips for insatlling it.
Old Feb 20, 2005 | 10:22 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
install tips
https://www.thirdgen.org/techbb2/sho...ram+%2Binstall
best place is either jegs or summit. if u want used ebay might have some but rarely dont
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
ebay and classifieds on this site is a good place for a used one. can save lots over new.
but jegs has it. forget the price tho. think its like 600-700 for the uppers
ebay has bigmouth manifolds for 380 here and there and some edelbrocks in the low 300's. get one of those and spend the money on new runner/lid kit from jegs. should come out with a decent setup for a few hundred less than from accel or other places.
Old Feb 21, 2005 | 12:06 PM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
Slot the bottom of the bolts so you can run them up with a screw driver. A dremel tool with cut off wheel will work fine. Drill out the 4 inner bolts and switch to a nut and bolt (bolt going in through top and bolt on the bottom. Use a lot of RTV on these 4 bolts to avoid vacuum leaks. These mods will take a 6 hour job of getting the Plenum on to a 1 hour job. Get yourseld a long 1/4 inch wrench along with the short one in your toll box and your all set. I have had a SuperRam since '96 and hated it until I made these mods.
Old Feb 21, 2005 | 12:11 PM
Car: 1987 Iroc-z
One more thing. Buy the proper size tap and run it through the plenum before install. (makes the screws go in a lot easier) Also might wanna use a little oil on the screws so they run up easier. All this cuz they are tuff to get to in some places. The screwdriver trick from the top saves tons of time, just remember to stuff some shop rags in the ports so you don't drop any screws/tools down the intake.
Old Feb 21, 2005 | 03:38 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
What works well for me is, i have one of those ratching boxed end wrenches. For the small bolts that hold the plenum to the runners. Not bad once you do it a few times.
Always good to go back and check everything after you put a few miles on the install. I always seem to have one or two bolts that loosen over time. Kinda like when you install a set of headers.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
no green
Jan 9, 2016 09:22 PM
mfp189
Sep 27, 2015 09:25 AM
Dragonsys
Sep 25, 2015 03:51 PM
