Knock sensor
Old Feb 23, 2005 | 03:57 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
Knock sensor
i was wondering if anyone knows what the torque spec for the knock sensor is supose to be. also is it supose to be on the driver side or passenger side of the block.
Old Feb 23, 2005 | 08:02 PM
brutalform's Avatar
A little trick for the KS is to tighten it until no coolant leaks out. Some, but not all KS are more sensitive than others, and having them a bit looser will make them less likely to pull timing out on you, hindering performance. This is one of the performance tips in the GM service manual. (also in the Howell Developments TPI manual also). Im not sure if there is indeed a TQ spec. but I never needed one.
The KS is usually on the right side of the block, but they can be located anywhere, in hopes to make them less sensitive.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
