stealth ram and fuel rails
Old Feb 24, 2005 | 01:24 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
can the stock fuel rails work with the holley stealth ram? if not then can my current afpr work with the aftermarket fuel rails?
Old Feb 24, 2005 | 12:02 PM
FactoryFreak's Avatar
Car: 1988 GTA
Transmission: TH350
No the fuel rails will not work, when you order the new rails just get the ones with the AFPR on them.
Old Feb 24, 2005 | 12:28 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
how about our stock Throttle body?
Old Feb 24, 2005 | 12:36 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
As far as I know it will fit...
Old Feb 24, 2005 | 12:49 PM
Car: 1988 GTA
Transmission: TH350
The stock throttle body will work but you may have to upgrade later depending on engine mods
Old Feb 24, 2005 | 01:07 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ok one moer question, I found the part number for the total fuel rail kit with afpr.. that price of 220 is a lil much I believe, is their a part number for just the fuel rails, and could I use earls fittings to make it all work, and would i still nee the holley afpr, or could i use my stock afpr thats currently on my tpi.
Old Feb 24, 2005 | 02:44 PM
ok one more question, I found the part number for the total fuel rail kit with afpr.. that price of 220 is a lil much I believe, is their a part number for just the fuel rails, and could I use earls fittings to make it all work, and would i still need the holley afpr, or could i use my stock afpr thats currently on my tpi.
As far as I remember with the HSR setup, you MUST use their fuel rails and afpr. You can check on www.stealthram.com to make sure. The number is 61-7540 for the rails without the afpr.
9192camaro
16
Feb 3, 2019 12:21 AM
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
L98GTA87
Aug 11, 2015 06:55 PM
