Distributer For HSR
Car: 1986 Iroc Camaro
Engine: 5.3 ltr
Axle/Gears: moser 9in, 4.56gear
Distributer For HSR
OK I'm thinking about getting a HSR for my camaro. I was wondering what distributer set up some of you guys are using with that style intake setup.
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Well, there are two distributor types for third gen (I think). Lrage cap and a small cap. My '87 came with the small cap and a remote coil. This small cap is the one I think you must install with the HSR. FWIW, I use an MSD distributor.
Engine: 5.3 ltr
Thanks for the tip doc. I currentley have the large cap hei distributer. Do you know if the plug for ignition module is the same? Mine is a 4 wire plug I think. Have looked at it in a while the car is stored for winter.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
You can buy an adaptor harness for the large to small cap distributors. I had one on my 86 when I went to a TPI setup.
I am running an MSD Pro Billet on my 88 Formula with the HSR.
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
I went to a local junkyard, and cut the harness out of a junk late model van, and just soldered them to my harness. I figured that I'm never going to put the large cap distributor back in, so I converted my harness. The wires are all the same color, they just have different plugs.
Engine: 5.3 ltr
Thanks for all the suggestions. I have one last question. Where can I get the adapter harness?
Gunner242
Dec 25, 2015 04:49 PM
drptop70ss
Oct 4, 2015 09:44 PM
