TPS part number request (I swear I searched!)
Car: A few
Engine: All Eights
Transmission: All kinds
Hello all.
My apologies if I missed it in searching. I am trying to get a genuine GM TPS for my L98 Formula. I have this Niehoff bugger on there and its performance has not been stellar (having tried everything else for the hot hesitation issue, including a few hundred searches, this is all that's left). Also, which company has the faster service, Dal's dealership (VanDeVere?) or GMPartsDirect? Thanks much in advance.
K
K
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
You should be able to go to any GM dealership and order the TPS. If you order it before 3 p.m., it will be the the next day as long as its not discontinued or something like that. I'm not sure how long GM Parts direct takes.
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Local dealer would be best and you don't even need to know the part #, they can look it up for you if you want. I agree, kneeoff or what ever they are called makes nothing but junk.
Car: A few
Engine: All Eights
Thanks folks. I am loathe to try the dealer because of the pricing here. Well, that and too many bad experiences in the past.
I know many have had good luck with Dal and GMPartsdirect so I thought it would be worth a shot. Hopefully someone with the number will weigh in this week, or I'll do as you suggested. Thanks guys.
K
K
Engine: SBC, LS-x
I even tried a web search before my last post. Spent a good 10 minutes on it and could not get a part #. If nobody here posts it, go to the dealer and get the part #. You don't have to buy it from them. Most of the folks at the parts counter are good folks and would gladly give you the part #. Then you can order online if you can get a better price.
Car: A few
Engine: All Eights
True, true.
Maybe the dealer won't be so bad. If it's under $50 I'll just buy it on the spot, since the Niehoff crap is close to that. (Edit: Close in price) I guess I became hooked on online shopping. Rockauto usually has the small parts, but even they carry off-brands for sensors...
Thanks!
K
Thanks!
K
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The sensor kit (TPS, bolts, washers) for a 1992 L98 is 17112368.
GmPartsDirect's price is $46.20 shipped.
VanDevere wants $56.95 before shipping and its a special order.
It is slightly less at NewGmParts.com at $53.68 before shipping.
I hope this helps someone.
Engine: 305TPI
Even without a Parts and Illustrations Manual, finding the number is not hard. Just go over to www.partsamerica.com and search. The OEM part number is cross-referenced when you look up the throttle position sensor for your application.
I'm glad to have helped Ken. You're welcome.
Car: A few
Engine: All Eights
Partsamerica?
Good to know. I use RockAuto and the local chains but couldn't get a part number.
Here's the kicker: RockAuto has the part but it has to be searched out by number, not by vehicle. And GMPartsDirect failed to accept my C/C info. Funny, I've had the card for nearly a decade and keep close tabs on everything with it so I wouldn't forget changing any info...
At any rate, I should have it shortly. Thanks again!
K
K
Engine: 305TPI
Partsamerica is Advanced Auto in my part of the country. Elsewhere it known under names the Checker Auto Parts, Schuck's Auto Supply, Kragen Auto Parts or CSK Auto, Inc. I thought this was fairly common knowledge.
Car: A few
Engine: All Eights
It is....
I didn't recognize the partsamerica name and simply plugged the part number you gave into RockAuto. I had used the Kragen page from time to time, but was unable to bring up what I needed several times and abandoned the page for napaonline and so on. The one time I try everyplace else it's there....heh
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
TA8487
Aug 16, 2015 12:21 PM
