Running way too lean
Car: 92 Camaro Z28
Engine: LB9
Transmission: world class T5
Axle/Gears: stock ten bolt
My car tends to lean out badly sometimes but i am not getting any trouble codes so what could be the problem? gas i use (92 octane) bad sensor?
Originally posted by hot92z
under idle but i fixed it...... it turns out speed density blows under cold weather conditions
Well, you get the idea. It was a good stop-gap, but you can see why the factory went back to MAF in '93.
eightsixseven
Dec 16, 2024 01:50 PM
