A quick intake question
Old Mar 14, 2005 | 09:31 PM
J-Bru-Ha Z-28's Avatar
Car: '91 Z-28
I have done several searches and have come up with nothing, the question being; is there a difference in the intake manifold of a MAF car and SD car. I am looking for a manifold on ebay to play around with but im not sure if the older ones will work on my '91 Z28. Any help would be great.
Old Mar 14, 2005 | 09:48 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
The only difference between the two is the plenum on the SD cars has a vacuum port for the MAP sensor. It won't make a difference though if you T it off an existing port on a MAF plenum. 88 and older also had provisions for a cold start injector in the runners. The bases are the same.
Old Mar 16, 2005 | 11:35 AM
Car: '91 Z-28
Just making sure I am getting things straight, the base or manifold for all TPI cars are the same no matter if they are SD or MAF is what you are saying correct? If that is true is there a difference in a base for a 305 compared to a 350?
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
happyhapka
Aug 15, 2015 04:42 PM
