wanting to get rid of my cold-start injector
Old Mar 15, 2005 | 03:40 PM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
I have an 87 Trans AM GTA 5.7L auto and im want to get rid of the cold start injector and a buddy of mine has an 89 GTA 5.7L that doesnt have the cold-start and i tryed to put his computer in my car but it wouldnt start it almost did but would just turn over and i plan to put HSR in soon but i know i cant have to cold start so what do i have to do to put his computer in my car to get it to work thanks for your help!
Old Mar 15, 2005 | 04:16 PM
clippjr8's Avatar
go to www.lsracingchips.com and buy a chip. There chip will fix all your problems.
Old Mar 15, 2005 | 04:56 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
You can also get into tuning it yourself and make a chip using the 89 L98 chip. The 89 models didn't have cold start, but they added more fuel in using the regular injectors.
You can also just find someone that is local to you and see if they can make you a chip and teach you how to do it. If you find them on here, you will need to pm them so you don't get in trouble with the mods.
Old Mar 15, 2005 | 05:32 PM
rsn932's Avatar
When I switched from my 87 TPI setup with the cold start injector to a Stealth Ram, I didn't get a new chip or anything. It starts fine even in like 20 degree weather. I'm going to do a custom chip soon anyway since it needs some tuning, but it works without it.
Old Mar 15, 2005 | 07:51 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Re: wanting to get rid of my cold-start injector
Originally posted by Dans87GTA
i tryed to put his computer in my car but it wouldnt start it almost did but would just turn over...
You have to disable the CSI somehow. You can pull the plug on the injector itself or it has its own fuse in the fuse box. Pull either one and it should start right up with the 89 prom or even the 86-88 setup. I know a lot of people are not fond of leaving the injector in the rail since it can leak, but for a temp solution it'll work fine.
Also you don't need the whole 89 ECM, just the prom.
rsn932-Thats been my experience also, CSI doesn't seem to do anything unless its really cold.
clippjr8, for $150 You can buy an adapter and a usb chip burner from craig moates and be burning your own. Anybody thats computer literate at all can figure out how to check some flags and burn a simple chip.
Old Mar 15, 2005 | 08:19 PM
clippjr8's Avatar
You are right. If your interested in burning your own proms and have the time to learn, moates is the way to go. If your not, then www.lsracingchips is the way to go. Its all in the person and what they want to spend there time on. It would not be worth it to buy the prom burning epuipment just to change some flags and thats it. But, in the end, you are right. Burning your own proms is the way to go if you want maximum power and driveability and the time to put into it.
Old Mar 16, 2005 | 07:14 PM
Dans87GTA's Avatar
thanks for all your help im going to try and pull that fuse so all i have to do is out his prom in my ECM or what? just want to make sure that im going to do it right
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
355sbcTPI
Aug 19, 2015 04:38 PM
tmellott89
Aug 16, 2015 02:58 PM
mustangman65_79
Aug 7, 2015 09:55 PM
