tbi to tpi aldl port modifications
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
for all of you that switched from tbi to tpi what did you do to your aldl ports to get them to work with the new ECM? my 92 has a wire already run to the M slot and I want to clip that and splice it into the E slot right? what do I do with the wire going to the M slot then?
I see that is for the F and 8 code cars, do you have that schematic for the E code cars?
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
we went from a V6 91 aldl to an 89 TPI harness. The aldl was fine and everything worked well with my scanner, and pulling codes.
Fast355
Dec 2, 2016 06:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Sanjay
Aug 12, 2015 03:41 PM
