change to TPI
Old Mar 20, 2005 | 08:52 AM
xandersdad's Avatar
Car: Now Camaorless
change to TPI
By what I've read on different posts, I'm correct in understanding that if I pull a complete TPI setup including harnes, computer and sensors from an 86 305 / 700R4 and transplant it into an 86 carb 305 / t-5 that it won't work? or should I say won't work without reprogramming the computer? I've never fooled with fuel injection or computer cars before so I am totaly "green" on the subject but I want to learn. Is there an "easy" way to do it?
Old Mar 20, 2005 | 08:59 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Yep, it will work.
Old Mar 20, 2005 | 09:03 AM
xandersdad's Avatar
Car: Now Camaorless
Originally posted by 406TPI
Yep, it will work.
Are you saying without any "reprogramming" the ecm from the 700r4 or with reprogramming it? I'm not concerned with horse power or anything right now, just keeping it stock with stock TPI set up.
Old Mar 20, 2005 | 09:29 AM
406TPI's Avatar
Car: 1985 IROC-Z
It will work without any reprogramming. Might have some idle down issues (deceleration), but it shouldn't be too bad. I ran a 700r4 eprom for a while with my T56 without any problems at all.
HTH
Old Mar 20, 2005 | 09:36 AM
SloNlo350's Avatar
Car: 2005 GTO
Engine: LS2
My situation is similar as well. I have a 4L60E so I have my original TBI computer running that and then the '7730 running the motor and it worked perfectly fine back when it was just a stock chip minus VATS. But there are plenty of people out there that will burn you a chip with just the "Transmission" value changed from Auto to manual (assuming the MAF computer is similar to the 7730 in that repect.)
Old Mar 20, 2005 | 09:43 AM
406TPI's Avatar
Car: 1985 IROC-Z
Well, it's not just as simple as switching a value in the .bin......there are other differences in the .bin files when you compare an auto to a manual.....they are small, but there are diferences......that being said....his set-up should run fine on the auto prom chip.
Old Mar 20, 2005 | 09:56 AM
xandersdad's Avatar
Car: Now Camaorless
Thanks for the info! I was scared there for a minute and was about ready to scrap the idea of changing it. Me not knowin much about computer controlled vehicles and fuel injection, it would a hard learn to trouble shoot if I did have problems. I've always been afraid I would fry something. What would it cost to have the prom changed?
jharrison5
Aug 19, 2015 05:53 PM
jbd1969
Aug 17, 2015 07:06 PM
Out-Cast
Aug 17, 2015 10:57 AM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
