Intake
Old Mar 22, 2005 | 04:35 PM
sam's Avatar
sam
Intake
Ordered headers and y pipe and should have them on by the car by the weekend
I guess the next thing should be the intake. Aprt from manufacturers such as slp. If I were to use the intake manifold from a 98 LS1 would it fit on an 88 305 TPI and will it result in a noticable improvements?
If Not, is it worth modifying the intake and throttle body manually or better to go buy a modded one?
Sam
Old Mar 22, 2005 | 04:54 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Improvements yes, fit no. Your comparing different engine styles all together.
Please go back and read this thread --> https://www.thirdgen.org/techbb2/sho...hreadid=151240
Should have plenty of ideas for you from the HSR, Miniram, modding the TPI, and LT1 conversions. Most peole consider one of the above unless they just want to do a full LS1 engine swap replacing the current powerplant.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
