engine swap help
Old Mar 28, 2005 | 09:24 PM
fastfbody's Avatar
Car: 1989 GTA trans am
Engine: L98 350 tpi
Transmission: 700r4 built
Axle/Gears: 3.45 4th gen 10 bolt
engine swap help
im going to be putting a 91 trans am lb9 305 tpi in my 1982 z28 camaro.i need to waht needs to be done for this to work.im geting the complete motor all the pullys and junk.im also getting the ecu and wireing harness.what will have to be done??? eltric fuel pump yes\no
Old Mar 28, 2005 | 09:29 PM
88cam's Avatar
thats a yes on the electric fuel pump. there really isn't much you have to do besides use the tpi wire harness and ecu when you wire it all in. its pretty straight forward and not much you have to do. vacuum lines may be your only issue and they're pretty simple too. you can do a search for a diagram in the forum for them I posted one once and others have done the same. good luck and if I forgot anything I'm pretty sure someone else will fill it in.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
