Where is the MAF Burn off relay....?
Old Apr 1, 2005 | 04:09 PM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
My 1991 Trans Am is acting funny and I was told to find the MAF burn off relay. I removed the MAF sensor because I thought that was the problem, but the car didn't idle or run any differently.
Old Apr 1, 2005 | 06:03 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
It's one of those over by the master cylinder. You can pull one of the screens off the MAF itself, carefully clean the wire with a Q-tip and some solvent and see if it helps. The MAF sensor and circuit is pretty reliable on these cars. I'd suspect something else and really need a scanner to monitor the sensors to catch it. Not at all unusual for a plug in connector to get corroded and start giving bad readings and causing poor running.
Old Apr 1, 2005 | 06:09 PM
9D1BURD's Avatar
Car: 1997 Z28
That was my attempt at an aprils fools joke being that my car is a 91(SD) and i was asking about a MAF relay.
Thanks though
Old Apr 2, 2005 | 04:23 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Hook, line, and sinker........
Old Apr 10, 2005 | 05:52 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Its my fault, I'm the bad person here. I posted under his account when I was at his house.
Old Apr 10, 2005 | 06:47 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Classic!
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
racereese
Oct 3, 2015 03:46 PM
