Injector help??
Injector help??
Hello,
I just bought a 1989 Iroc and this is my first post. It has a 350 TPI and I am needing to replace the injectors. Does anyone offer the stock 22lb injectors in a low price range? I was thinking of going with the Accel 21lb ones until i started searching this forum. I see everyone prefers the Ford 24lb injectors. Can I use these with the stock computer? If not, how much does it cost to modify the computer? Any other options?
Thank you in advance
Eric
Eric
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
From prior posts I have chosen to stay away from Accel injectors. The SVO injectors (lb per hour that you need) would be a much better choice and can be found from either summitracing.com or jegs.com for a decent price (read as...best price).
Modifying your computer is a different story. There are many options to alter the bin and you'll need to do some reading on the DIY PROM board. I use the Prominator, an ALDL cable, Laptop and Tunerpro. The Prominator, ALDL cable and a $30.00 donation for the software were my costs, IIRC approx. $300.00.
Welcome to TGO and good luck!
thejimsterz28
Sep 15, 2015 04:37 PM
