Would a clogged fuel filter cause no fuel pressure?
Old Apr 10, 2005 | 08:22 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I've got some problems. Today, I started the car, ran fine, no problems at all. About 5 hours later, it started, then died. Now, it will not start at all and I have no fuel pressure. The car has been sitting in the garage for about 6 months without being started..thought maybe it might have bad gas....which is possible..but...no fuel pressure? Just trying to think of things it could be before I think about replacing the fuel pump Any takes on this? Would a clogged fuel filter cause this?
Old Apr 10, 2005 | 08:33 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
If it were -really- clogged, maybe. Does the pump prime with the key turned forward? Have you tested the pump by applying 12v to the 'G' terminal to bypass everything else?
Old Apr 10, 2005 | 09:38 PM
Engine: 5.7
I haven't tested the fuel pump yet...that will be the next thing to try. I just went out in the garage...the car started fine...fuel pressure is fine...like there is nothing wrong. Now that it's running fine...I can hear the pump prime...I tryed it several times and it sounds fine...
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
bryan623
Mar 22, 2021 06:43 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
