new 383, serious problems
Old Jan 7, 2006 | 02:02 AM
  #51
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Originally posted by Shagwell
- I know this is an older post, but .68 is high for idle TPS reading. need to reset TPS to .54 - That would also screw w/ the chips programming. It'd be reading idle MAP, but part throttle TPS...
That's from having adjusted the idle without doing the minumum air procudure first.
Originally posted by ar91c4
...I had to set that idle screw up a while back to get the car to idle so they might be a little open when idling...
Some TPS aren't adjustable, on restart the ECM reads the TPS voltage and uses that as the base setting.
Old Jan 8, 2006 | 09:28 PM
  #52
Shagwell's Avatar
Car: projects.......
hummm, never seen a TPI TB that didn't have an adjustable TPS... also, if his new motor has higher compression(9.5 or better) 41 degrees timing would be A LOT for 93 octane...well, if thats at 2k, I guess its not horrid, but at WOT, you'd be asking a lot out of pump gas....
Old Jan 8, 2006 | 10:24 PM
  #53
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
The tpi will choke the crap out of a 383. Ive got that john lingenfelter book on small block chevys. He said throwing a tpi on a 383 gives a new meaning to induction limited, its like throwing a 283 2 barrel intake and carb on the car.
Old Jan 9, 2006 | 09:44 AM
  #54
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
That is an extremely broad statement. I would agree that any production stock TPI setup, would not be ideal. If you have a look around this site you will see hundreds of fellow enthusiasts, who have modified the TPI to work really well, with 350's 383's and even 406's. The type of intake a person is going to use is heavily dependent on application. Unlike sticking a 2 barrel intake on a 383, an TPI may be able to provide the torque that is needed to move a large custom cruiser, such as an old Merc. A TPI is capable of producing a very high and flat torque curve on a high output motor without sacrificeing to much HP. This is not to say you could not mak significantly more HP with a different setup. As with every aspect of car building there are many comprimises.
Old Jan 9, 2006 | 11:05 AM
  #55
Car: 1991 Z28
Engine: SBC
yea i completely agree with you...i just quoted it from the book i had, thats where that statement came from
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
gixxer92
Sep 1, 2015 04:32 PM
LT1Formula
Aug 20, 2015 09:36 PM
sreZ28
Aug 14, 2015 07:48 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
