TB Coolant Bypass
Old Apr 3, 2005 | 07:51 PM
klumb15's Avatar
TB Coolant Bypass
i got this new TPIS twin 58mm throttle body that i'm gonna put on my HSR, and the guy i bought it from said that i had to do a TB coolant bypass because something with the TB....how exactly do I go about doing this?
Old Apr 3, 2005 | 08:30 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You have radiator coolant fluid going into the TB and out. All you need to do is to locate these two rubber lines, pull them off of the TB and joine them together.
BTW: there is a tech article on this mod on this 3rd gen board, check it out.
Old Apr 3, 2005 | 08:31 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
BTW: you are in Michigan. You can always come over and look at my car, I'm in Newport just North of Monroe.
Old Apr 3, 2005 | 08:42 PM
Krazzycowgirl's Avatar
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
Pull off the hoses & run down to Ace hardware & get some rubber stoppers & then put them on.
Old Apr 3, 2005 | 08:48 PM
klumb15's Avatar
hey doc your north of monroe? i'm heading down that way april 22nd i believe for the jefferson car show, you gonna have your car there? it sounds relatively easy, just connect two hoses together..i just never knew what it was all about...i didn't really look at my new TB, is there just not a inlet and outlet for coolant or what? do they just delete that to make the in coming air have a cooler charge or what?
Old Apr 4, 2005 | 02:58 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
TB Bypass
$750 L98
Feb 1, 2025 02:25 PM
sheachopper
Jul 31, 2019 11:27 AM
