Ok to use rubber hose to connect AIR to cat>
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
My original metal line is pretty fugged up and wanted to know if I could run a few inches or so to join it to the cat inlet. Would make swapping in an ORP alot easier as well.
Will
Will
A section of hose may survive, depending upon its proximity to the exhaust system. What area/section would you replace? If it is right at the cat inlet or along the side of the cat, I wouldn't recommend it. You might want to investigate your options with metallic tubing and compression connectors, or consider a 3-way cat with no air injection inlet.
Car: 91 formula
Engine: 355
there's special hose made for air injection, should be able to get it at any good parts store, but even it doesn't survive if you can't get it a few inches off the cat
Axle/Gears: 9-bolt/3.45
Compression fitting here too.
The tubing used in air tube repair kits is copper--with silicone hose and clamps to piece it all together. But compression fittings make a much cleaner-looking job.
You can get 1/2" OD copper tubing and a couple of compression fittings from any home improvement store.
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
