You'll need to change the PROM to a 350 one.
Also the 350 you use will have to have 87and up style heads if your car is an 89. You'll also need a knock sensor for a 350.
Former Sponsor
You'll need the following:
the 350
350 knock sensor
350 memcal
22 lb injectors
All your other TPI parts will work fine.
the 350
350 knock sensor
350 memcal
22 lb injectors
