Fuel injector drivers
Old Apr 11, 2005 | 02:21 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
If my fuel injector drivers are bad is there a way to test them. If they are bad how can i get them repaired and who can do it and for how much? Thanks.
Problem: The car starts fine, idles fine, after running for a minute or so it runs rought at higher rpms and if it is turned off it will not restart. the #7 injector is a 3 ohms, and number #1, and #2 injectors are at 13 ohms, all the others are at 16 or 17.
I disconnected the 3 ohm injector, ran it, turned it off, but it would not restart.
Old Apr 11, 2005 | 08:04 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
1) The "injector drivers" are located in the ecm more as a force. Forget about replacing them.
2) The injectors should ohm from lead to lead @17ohms.
3)Injectors #7, #1 and #2 are gone. #7 is shot.
4)Replace the whole set of injectors not just #7 #1 and #2.
Old Apr 11, 2005 | 08:15 PM
pellmanm's Avatar
Car: 1989 GTA
I just bought a set of accel 24 pound injectors, i will put them in this weekend, i did just remove the connector from the 3 ohm injector and it did not make a difference. the car will still not restart after it is shut off after it has been running.
I have to wait a while before i can restart it. Could it be something else like the ignition module. Or is it just the injectors?
Old Apr 11, 2005 | 08:28 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
You have those great crappy multecs on there now. I'd rethink those accel injectors... do a search, we've had some good colorful threads on 'em. Do a little research before deciding on those. Follow links in these threads for more.
https://www.thirdgen.org/techbb2/sho...24#post2282124
https://www.thirdgen.org/techbb2/sho...hreadid=274731
Old Apr 12, 2005 | 01:49 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Ive never used accel but i have heard alot! of bad stuff about them, not only on here but i have heard bad stuff frequently on other boards.
Read the post made by RedDevil. But read them thorouly.
bryan623
Mar 22, 2021 06:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Bryan F
Aug 18, 2015 02:28 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
