Fuel injectors
Old Jan 13, 2005 | 06:17 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
Fuel injectors
Im going to replacing my fuel injectors prolly within the next month or so. Prolly going to replace the factory ones with something else. Any ideas as to which brand...or what lb? the motor in my car is all stock, with the exception of my ram air kit...exhaust....misc lil things like that. Thanks guys.
Old Jan 13, 2005 | 06:38 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
You have a 305 TPI, so with no doubt, buy the 19#/hr Ford Racing fuel injectors. They will fit just fine and are gotten at a lower price than anything else, and the quality is top notch.
Old Jan 13, 2005 | 11:07 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
I will shout this at you...
DO NOT BUY ACCEL INJECTORS!
I'm done.
Scott
Old Jan 14, 2005 | 02:55 AM
ZZsmpch's Avatar
I guess I must be lucky, 20K on my Accel injectors so far without a hitch.
Old Jan 14, 2005 | 07:36 AM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
I'm knockin' on wood for ya' buddy.
One went dead after about 600 miles and now the replacement just died.
Old Jan 14, 2005 | 10:36 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
How big are the injectors?
Old Jan 14, 2005 | 01:29 PM
ZZsmpch's Avatar
19# They are about 3 years old. Did you ever get the feeling by saying something you jinx yourself. Now I'm gonna start to worry every time I drive. I have two sets of Ford 19# injectors on deck out in the shop though. Luckily, I keep my feathers numbered for just such an occasion.
Old Jan 15, 2005 | 08:34 PM
TorchRay's Avatar
Car: 89 WS6 Formula
well thanks for the responses guys. I have a question though. When you change your injectors...did anyone have to do anything with the computer at all. adjusting anything. Someone told me that i needed to hook a labtop up to my car and look at the readings and maybe adjust the fuel with an adjustable fuel pressure regulator. Any thoughts on this??
Old Jan 16, 2005 | 10:59 AM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
If you are replacing your injectors with with stock replacements (ie. replacing #19 with #19) then it's just a R&R job.
Scott
PS Dont take your chance with Accel. There are an equal, if not more, number of people who have had problems than not with this brand.
Old Jan 16, 2005 | 11:52 AM
TorchRay's Avatar
Car: 89 WS6 Formula
Cool. Another question. What rate of flow does the ford 19lb injectors flow at? If i change my stock ones with ford motorsport runs...am i going to have to tinker around with a computer and mess around with an adjustable fuel pressure regulator??
Old Jan 16, 2005 | 03:34 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
I don't think so. I was also under that impression but check this link out...
Ford Injector Flow Test
Old Jan 16, 2005 | 08:34 PM
TorchRay's Avatar
Car: 89 WS6 Formula
I went on summit racings web site and found a set of ford injectors rated at 19lb which is what i believe that my formula has in it(correct me if im wrong please?). check out the data below.....i should be able to pull mine out..and put these in without having to fool around with the fuel pressure and stuff right? If i have to..let me know what i have to do. Tried doing a search on the net...didnt find to much though.
Ford Racing Performance Parts
Product Line Ford Racing High Flow Fuel Injectors
Injector Advertised Flow Rate (lbs/hr) 19
Injector Advertised Flow Rate (cc/min) 202
Quantity Sold as a set of 8.
Injector Impedance 14.5 ohms
Driver Type 12V saturated circuit
Overall Height (in) 3.045
Seat to Seat Height (in) 2.563
Manifold O-ring Outside Diameter (in) 0.545
Fuel Rail O-ring Outside Diameter (in) 0.523
Outside Diameter (in) 0.982
Injector Plug Style Bosch/Amp Style
Wiring Harness Included No
O-Rings Included Yes
Notes (Not Specified)
Old Jan 16, 2005 | 09:35 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Ok did some more searching around and found another set. I got this info off of five0motorsports.com
These injectors are 22lbs. According to the site 88 was the last year for the 19lb inj for firebird and 89 mwas the start of the 22lbs. Heres the info.
Bosch/Ford - 22lb
TPI 305/350
BRAND NEW Sets
0280150561-D9B
Fitments:
1989-92 Camaro TPI 305
1985-92 Camaro TPI 350
1985-91 Corvette L98/LT1 350
*Special Note to our customers:
Both the D5B and D9B Bosch sets have been cross-referenced to fit the TPI intakes listed above.
Remove the original retaining clips for installation - those clips were part of the original installation and are not needed with the Bosch fuel injectors
Old Jan 16, 2005 | 09:39 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Did another search and found these off of fiveomotorsports.com
According to the site...88 was the last year that 19lb inj were used in camaro and firebird and that 89 was the first year for the 22lb inj. Heres the info...you be the judge tell me what you think.
Bosch/Ford - 22lb
TPI 305/350
BRAND NEW Sets
0280150561-D9B
Fitments:
Old Jan 17, 2005 | 01:46 AM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Been there, done that
fiveomotorsports.com injector issue
This is what prompted me to take a chance with Accel. Bad move on my part.
No matter how many times I said "why?", Bruce Holts' reply was "I would never sell you the #19 injectors for your car". He states thats what the earlier 305's came with.
Everybody else on TGO says #19's and quite a few people have them installed with no lean problems at all.
I've never seen anything official denoting #19 for 305's personally but if you go to your local Pontiac Parts department, they'll tell you the part number and rating.
And, if you do that last part, let me know because I keep forgetting when I'm there
Scott
Old Jan 17, 2005 | 08:12 AM
TorchRay's Avatar
Car: 89 WS6 Formula
Well i think im getting just as confused as you are..lol...so basically if i go with the 19lb inj i should be alright and i wont have to mess around with anything right?....or should i go with the 22lb'ers?
Old Jan 17, 2005 | 10:06 AM
vernw's Avatar
Axle/Gears: 4.11 posi Ford 9"
I don't believe the info about the 19# injectors posted above. 19's were used on all the 305 TPI cars up through at least 1992. My 91 had them in the factory 305 TPI I pulled when I dropped in my 383 last summer.
Go with the 19# injectors and the afpr and prom stuff won't be required for your setup.
Old Jan 17, 2005 | 10:31 AM
TorchRay's Avatar
Car: 89 WS6 Formula
Well thanks for all the great info guys...looks like the 19s ill be going with. Hopefully i wont have a prob.
Old Jan 17, 2005 | 10:32 AM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
I agree, go with the 19's, and if you don't have an AFPR, now's the time to put one in.
That's what I'll be doing (not the AFPR, got one of those already )because I don't feel like putting in another Accel and having it crap out a few miles down the road.
I don't know your mechanical skills so I will say this; take your time if you are doing this job yourself. Changing the injectors is a fairly simple job but one you must pay attention to. On a side note, you might as well check if any or your intake manifold bolts are loose while your there.
Have fun, I know I wont the third time around.
Scott
TPI Injector swap
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
