Getting too large of injectors just like getting an oversized carb?
Old Apr 20, 2005 | 01:48 AM
Meatwad's Avatar
On Probation
Car: 1987 IROC
Engine: 350?
Transmission: 700-R4
I do not know for SURE what my engine internals or the size of my injectors. I was told they were 36lb but I am not for sure.
Old Apr 20, 2005 | 09:31 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Too large of injectors without a computer tune is just dumping unneeded fuel into the cylinders. It would be a good idea to figure out as much information about the motor as possible. If you look on the back of the block near the distributer you will find a stamp on the block. This will tell you what size motor you have in there. I personally do not know how to check the size of the injectors without actually having them flow tested. Maybe someone else will be able to tell you.
Old Apr 28, 2005 | 11:10 AM
hotrod85z's Avatar
Car: 1986 camaro
Engine: 5.7 HSR
Transmission: 700-r4
Axle/Gears: 3:42 auburn
if you have a 305, you'll have 19lb injectors, if you have a 350, they'll be 21 lbs injectors i believe, i know i went with 24 svos on my 355 nd now i have to give it throttle(open air) to get it to crank
I think i need a larger throttle body to compensate for the fuel
after market injectors go from 19, 24 36, 48,52 lb and some even go up to 96 lbs!!!
Old Apr 28, 2005 | 10:32 PM
WhiteKnight's Avatar
Car: 88 GTA
Transmission: Manual
you can have too large a carb? i dont know much about carbs... can someone fill me in on why too large a carb is bad?
Old May 1, 2005 | 10:50 AM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
Meatwad its sounds like you dont kknow who the previouse owner is ?
If it has 36 lb injectors there is a possibility that you might have a larger motor than a 350 than cross referencing the block numbers will mean nothing.
What color are the injectors ?
Old May 1, 2005 | 04:18 PM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
too much carb will make the car bog off the line...theres other stuff i just cant remember what else right now.
midge54
Dec 27, 2019 04:14 PM
Jae992
Aug 27, 2015 09:07 AM
hayesaw0210
Aug 23, 2015 11:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
