Quick question about sensors
Old Apr 20, 2005 | 12:17 PM
bigals87z28's Avatar
Car: Check The Sig
Ok, I broke off the two sensors that are in the front of the intake base. I know one is the Coolant Temp Sensor, but what is the other one? I tried looking it up in a few books, but cant find it.
Old Apr 20, 2005 | 02:32 PM
rsn932's Avatar
is it the sensor that tells the cold start injector when to add extra fuel?
Old Apr 20, 2005 | 06:27 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
i broke this sensor too (if it is the same one) when I was replacing the CTS. Im sure this isnt the technical name but it is the EGR coolant temp sensor, at least that was the one I broke it was a little bigger then a regular cts and had a connection like a fuel injector. If you can show a pic I can confirm it, I got it from a parts store at a mechanics price at $50 I thought it was a little pricey.
Old Apr 21, 2005 | 02:37 AM
Car: Check The Sig
From your discription, thats what it sounds like.
Its bigger then the CTS buy a good amount, and the actual part that goes into the coolant path is much larger. I might be able to reuse it, but its got a lot of degreeser on it.
Old Apr 21, 2005 | 08:53 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
The one you broke is the cold start switch, for the cold start injector.
It, and the EGR temp switch, and MAF modules are expensive.
I'd look into upgrading to and 89 ECM, and EPROM (deleted cold start injector, and MAF module.)
Old Apr 22, 2005 | 11:58 PM
Car: Check The Sig
I had the thing cross referenced, and it comes up as an EGR Coolant temperature switch. Im gunna try and see if it still works. If not, I am gunna have to use my powers to get one at cost. Most prices I picked up were 90 and above.
Old Apr 23, 2005 | 01:12 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
...it was a little bigger then a regular cts and had a connection like a fuel injector. If you can show a pic I can confirm it, I got it from a parts store at a mechanics price at $50 I thought it was a little pricey.
As you know the injector connector has 2 wires, the EGR Temp switch is a 1-wire sensor.
This is the sensor you described.
There's no EGR coolant Sensor because the sensor only senses the temperature at the base of the EGR valve (that's were it's located,) and the correct name is EGR Temperature Diagnostic switch.
In this picture it's the sensor with the green wire in front of the distributor, this is an aftermarket intake that required Exhaust Gases to be plumbed from the headers, the adapter pipe also has a threaded boss for the sensor which is normally at the base of the EGR valve.
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
