Corvette Block with Camaro Oil Pan?
Car: 1986 IROC-Z
Engine: 355 TPI
Axle/Gears: 3.23 Posi
Hi guys,
Have a 1991 corvette L98 block 2 bolt mains 1-piece rear main I am swapping into my 86 IROC 305 TPI. My question is will the oil pan off of my Camaro work on that block? I am pretty sure from what I understand that I cant use the corvette pan due to clearance problems.
Can someone who has a vette block fill me in? If neither will work what do you recommend as a cheap replacement? Also should I just get a stock oil pump for the 91 vette motor or a different one?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Isn't the 86 a 2 piece rear main? If so, I don't think you'll be able to put that pan onto the 1 piece RMS block.
Engine: 383 Carb
Transmission: 4L60
You're probably right, 86 was one of those bastard years.
In that case, yes, it will work just fine.
Car: 1986 IROC-Z
Engine: 355 TPI
So I should be fine as long as it's a 1-piece RMS? I sure hope it is! Any more money on this swap and I'll be in the poor house
Is there any way to tell from under my Iroc or do I have to wait until it's outside of the engine bay after we take the engine out?
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally posted by Bimma86.Is there any way to tell from under my Iroc or do I have to wait until it's outside of the engine bay after we take the engine out?
Car: 1986 IROC-Z
Engine: 355 TPI
Both dipstick's are on the passenger side's, right? You'll be fine...
I just wish someone with a vette L98 motor would chime in and tell me for sure.
So this is a definate NO on the vette oil pan in my Iroc correct? So to clarify what you all are saying is that, if my 305 is a 1PC RMS then it should fit the Vette L98 fine since they are both passenger side dip sticks correct?
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
So, yes...
Engine: 383 Carb
Transmission: 4L60
Originally posted by thirdgen88
I think the general point of this was that if the dipsticks are both on the passenger side, then both blocks are 1pc RMS.. Because of this, you'll be alright...
Car: 1995 Corvette
I forgot about the 80-85 engines... I guess it could be a 2 PC RMS with a passenger side dipstick (which I'm guessing is what you meant Apeiron?).. Guessing aside, you should be able to tell by pulling the torque converter inspection cover and looking at your current engine..
Engine: 383 Carb
Transmission: 4L60
I was trying to point out that the dipstick on the passenger side isn't a definitive indication that it's a 1 piece RMS, but something got lost in translation.
Navy8125
Aug 21, 2015 09:32 AM
