POP! sound through exhaust at idle
Old Apr 20, 2005 | 12:56 PM
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
I was trying to imagine in my head what would make a pop sound at idle but wasnt sure. its a LB9 305, it idles fine and every here and there there is a random pop out the exhuast. maybe 1-3 per second. not very loud but louder than normal combustion. it doesnt seem to effect performance, but is this common? I think old plugs and wires might do this?
i dont think its the problem, but my y-pipe has rusted enough to seperate from the catalytic converter, the pipes still line up, but technically they are totally separated. some kinda backpressure stuff doing on possibly??
thanks
Old Apr 20, 2005 | 02:31 PM
rsn932's Avatar
i would say the pop sound is just the massive exhaust leak from the ypipe not even being connected to the cat
Old Apr 20, 2005 | 07:45 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
could be an intermittent misfire.
Old Apr 20, 2005 | 07:48 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
when I had an odd poping sound out of my exhaust, it turned out to be a rocker that was loose and I guess wasnt opening or closing that paticular valve. I tighten it down and the pop went away.
Old Apr 21, 2005 | 08:52 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Old Apr 21, 2005 | 09:13 PM
Engine: 305ci TPI
the thing is is that it is random and doesn not follow any pattern, like every 8th pop is a loud one, its not like that. and again not real loud, but now that i think about it being a missfire that might make sense.
if a cylinder missfires and does not burn the gas in it, that gas will combust either when it is pushed out in the maniflods or at the next spark right, i guess that would make a sound like im hearing.
Old Apr 22, 2005 | 08:51 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
A few of my plugs got fouled this year causing a misfire. I also had that "pop" once in a while when it was idling.
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
gta power
Aug 13, 2015 06:15 AM
