rocker arms
Old Apr 21, 2005 | 01:38 PM
ol'blue86's Avatar
Car: 86 IROC Z-28
Transmission: 700 R4
rocker arms
I have an 86 IROC Z-28 with a 305 tpi. i'm getting ready to install a set of 1.6 roller rockers. They are not self aligning. I was browsing through the FAQ boards and i read that if i dont have self aligning rocker arms, that i would have to pull the heads and what not. I was expecting a quick and easy swap. Can somebody explain to me what i would need to do. Thanks. Will
Old Apr 21, 2005 | 02:38 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
you need guide plates then
Old Apr 21, 2005 | 04:18 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
i dont believe that 86' used self aligning from the factory.... you should b fine.
Old Apr 21, 2005 | 11:11 PM
hereitgoes's Avatar
Car: 1986 F250 4x4
Engine: 365HP, 510 lb/ft TQ 460
Transmission: C6
More than likely, like Smurfin' said, you shouldn't need guide plates. Several times, I've run into problems with the guideplates actually screwing up geometry, and pushing the rockers off center and causing all kinds of headaches, up to and including broken guideplates.
BTW, Spanky, when are you posting, at school?
Take it easy, and call me when the R/A's show up.
Brandon
Ed1LE
Sep 30, 2018 09:14 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
