TPI surging when heat is on??
Old Apr 30, 2005 | 11:25 AM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
Any suggestions on why my car will surge with the heat on?
I noticed it about a week ago and it stopped. It started again a couple days ago. I have only tried it with defrost on and it seems like the motor is dieing and catching back up?
It doesn’t seem to do it as much when I step in to it? Any thoughts?
-Tony
Old Apr 30, 2005 | 11:46 AM
Vader's Avatar
In the DEFROST position, the A/C compressor is allowed to cycle on to help dehumidify the incoming air before it is heated. You may be noticing the engine idle RPM being affected by the cycling of the A/C compressor.
Old Apr 30, 2005 | 08:19 PM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
i was aware of a small surge but this is about a 400-700rpm surge. I have never had this excessive surge when in defrost.
-Tony
Old May 3, 2005 | 08:27 PM
Vader's Avatar
Yes, that does seem excessive. Is the IAC functioning? Air passages clean?
Old May 3, 2005 | 09:21 PM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
umm not to sure.. it has stoped as of the last two times i drove it.. wierd.. ill check all the air and the heater vacume lines to see if its the problm.. hmm.. wonder if the compressor is locking up and letting go.. ill look in to that next time it surges.. if any one has seen this lemme know..
thanks
-Tony
Old May 4, 2005 | 01:08 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Definitely check the heating/AC system vac lines. Since the direction the air flows is controlled by vacuum, a bad line could be being "called" and causing a vac leak on ya.....
Old May 4, 2005 | 02:16 PM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
thanks for the sudg.. i will check it out..
_T
bamaboy0323
Sep 3, 2015 06:07 AM
stalkier
Aug 21, 2015 01:54 AM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
