MAF Sensor Relay?
Old May 2, 2005 | 12:38 AM
PoorBoyRS's Avatar
Car: 92 RS, 87 Formula, 89 IROC, 05 SRT4
Engine: 5.0 TBI, 5.7 TPI, 5.0 TPI
Transmission: 700R4 x2, T-5
Axle/Gears: 2.73, 3.42 posi x2
MAF Sensor Relay?
I've been trying to figure out what the problem be with my MAF sensor... everything I've read says that there is supposed to be a MAF Relay with a 5-pin connector that goes between the maf and ecm, and a 3 pin connector that goes directly to the maf. My setup has a 5-pin connector that goes straight to the maf sensor, and I was wondering if it is built in or actually separate. the system i'm using is from an 86 TA 5.0. Any help would be greatly appreciated
Old May 2, 2005 | 05:34 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Re: MAF Sensor Relay?
Yes one relay is a maf power relay and another is a maf Burn off relay which is when the car is off its sends a surge of power through that single wire you can see in the Maf and burns off any impurities or debris.
Old May 3, 2005 | 08:40 PM
Vader's Avatar
It should be something like this:
Old May 4, 2005 | 12:04 PM
PoorBoyRS's Avatar
Thanks guys, hopefully I can get her runnin smoothly soon.
BumpaD82
Feb 26, 2016 02:57 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
earlpote
Sep 12, 2015 11:55 AM
Gunsbee
Sep 7, 2015 07:10 PM
