New injectors, won't idle
Old May 4, 2005 | 05:10 PM
92 Rag's Avatar
5.7 1987 GTA: I'm posting for a friend.
he changed injectors, now car won't idle at all. What did he do wrong, what could have happened? He says he didn't touch anything else.
The injectors are new aftermarket he bought at a speed shop.
thanks.....
Old May 4, 2005 | 05:23 PM
brutalform's Avatar
Can you provide a little bit more information? What brand? What flow rate? etc.
Old May 7, 2005 | 05:29 PM
92 Rag's Avatar
Ok guys they are 24 lb Accel injectors. I will have the car at my place on Monday.
So anybody know if anything else should be changed/adjusted with these injectors?
Old May 7, 2005 | 06:55 PM
brutalform's Avatar
Im not knocking Accel injectors, as I use #36 on my engine. It is my understanding that there has been some quality problems with the Accel #22, #24, #26, injectors. This thread could become a mile long, from members who have had problems with them.
Dont get worried though. Start by getting your fuel pressure to 43 lbs, and work from there. If you install the #24s on a stock, or mildly modified engine, you will have an idle issue. Im sure you can use an AFPR to smooth it out.
Old May 7, 2005 | 08:23 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
prom prom prom and oh yeah PROM
Old May 7, 2005 | 08:24 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Did you reprogram the chip? 24lbers flow 10% more than stock, that's pushing it over the top edge end of the ECMs adjustment range.
If the ECM hasn't been updated with the new injector flow rate, the static (no vacuum) fuel pressure would have to be reduced to 37psi so that the flow is at the stock flow rate as a starting point.
squareroot of (Newpsi/43.5psi) x InjectorFlowRate=NewFlowRate
sqrt(37psi/43.5psi) x 24lbs/hr is approximately 22.1lbs/hr
Old May 7, 2005 | 09:02 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Make sure all the injectors are seated properly with no leaks.
Old May 8, 2005 | 11:40 AM
92 Rag's Avatar
Thanks guys....I wonder if he should just put his stock ones back in? He had one bad one that was cracked. Maybe just get one new one and call it a day...I don't think he cares about all tat more performance but I'll ask him.
Old May 10, 2005 | 01:36 AM
87 Iroc G92's Avatar
Car: 87 Iroc G92
Transmission: t-5
i just swapped to 24# svo's from 19# 305 injectors on my 350 crate motor, still running the 305 prom (acyd1139). I had to lower the fuel pressure from about 45psi, to about 35psi, cause it idled at 2000. definetly need prom tuning
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
justin57
Aug 20, 2015 07:05 PM
