1 or the other, heads or cam on a modded 5.0?
Old May 5, 2005 | 05:57 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Let's say you had to choose 1 or the other. Which one would you choose and why? If this is a silly question then answer why? What gains would getting World Heads on my car if it had the following mods: LT1 intake, headers, 3.73's?
If I go with either heads or cam, I will do springs for higher shifts thanks to the gears and intake.
Please correct me if my thinking is out of whack, but nicely.
Old May 5, 2005 | 07:12 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
Go with heads. Thats where the powers at.
A good cam is useless if you cant flow the numbers.
Small motor& big cam = loss of power.
Heads With minor bowl work and small combustion chamber and a thin head gasket might give you around 60 horse with the same cam.
Personally I wouldnt tear down a 305 and sink money into it I would just replace it with a long block 350.
or bigger
Old May 5, 2005 | 09:12 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
well now he said nothing about a 350 now did he? If i were you i would save money and do both at once, you will get the biggest gain from doing both especially since you will have the motor apart anyway. a good set of heads and cam will enable you to go beat upon the 350 guys, they dont like betting beat by 305s, especially the C4 corvette guys, they get pissed.
Old May 6, 2005 | 07:21 PM
robsgta's Avatar
I did read the last line... Sink the cash In a fresh 350 or bye a stroker short block off e bay
Old May 6, 2005 | 09:22 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
To answer your question heads without a doubt. However if I was doing it I would spend the money on a 350.
Old May 7, 2005 | 10:38 AM
robsgta's Avatar
Echo Echo Echo
Old May 7, 2005 | 12:52 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I have a comp cam in my 305.
It is nice and helped in power
But I helped put in a cam and heads in a buddy's 350, and wow! What a difference!!
Think about it. If you are going thru the trouble of doing either, you might as well do both!!
Make sure that everything that is going on your car will move over to a 350 once your 305 blows.
I'm gonna do that when on mine.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
NWAsonoma
Aug 18, 2015 05:45 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
