Car Surges Then Dies!
Old May 7, 2005 | 04:42 AM
moneyman380's Avatar
Car: 1991 Z28
91 z28 tpi speed density
Engine runs fine untill after it heats up (usually) then out of the blue the engine light will come on and the engine will surge spuratically. Most of the time its at idle at a stop sign or light. The service engine soon light comes on right as the car loses power and starts to surge. You can try to gas it but it will only get worse.
Checked for codes, but doesnt save any.
Logged on computer but dont know what to look for.
Not sure where to even start.
Old May 7, 2005 | 09:25 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
check voltage at tps, have ingnition module checked. set base timing. pull the plugs this is the best indicator of how the engine is running.
Old May 7, 2005 | 12:58 PM
Car: 1991 Z28
ignition module was check at autozone twice, reset timing, new plugs, Could it possibly be my MSD box?
Old May 8, 2005 | 10:28 AM
jamon8's Avatar
Engine: 350 tpi
find someone with a scan tool and take a drive untill the problem occurs. If you are planning on keeping this car for a long time invest in one. It has a lot better info than I do.
Old May 15, 2005 | 02:32 AM
Car: 1991 Z28
turns out it was the ecm,, swaped it out and it runs fine
Old May 17, 2005 | 04:02 AM
91RSHawaii's Avatar
Car: 1999 30th Anniversary Pontiac T/A
From what it sounds like, I have the same problem as you, with the surging and all... how would I check if it really is the ECM?
Old May 17, 2005 | 06:06 PM
Car: 1991 Z28
I had a backup one, so i just swapped it out. Along with a new eprom
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
