HELP ignition rotor will not fit on my TPI
Old May 7, 2005 | 02:20 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
I put an ACCEL cap and rotor on my car the cap fit good but the rotor from accel would not fit on the distributor shaft. so i figure a guess a need a ac delco rotor so i buy it and it will not fit on the distributor shaft. I looked at the old on and it is from acdelco i do not no what is wrong here The distrobutor shaft is not bent or anything. I need help car show is coming up.
Old May 7, 2005 | 03:58 PM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
When I replaced mine I had a similar problem. It just fit tight for some reason. The old was hard to get off also. Think I had to break it off even. I just pushed on and it fit.
Old May 7, 2005 | 07:30 PM
Car: 91 formula
I DID IT i went out and bought a Borg Warner rotor. It fits like a glove.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
Sanjay
Aug 12, 2015 03:41 PM
92projectcamaro
Aug 6, 2015 01:20 PM
