win aldl
Old May 8, 2005 | 10:33 PM
lawrence_1md's Avatar
Car: 86 MonteSS/ 92 Camaro RS
Engine: 350 TPI / 305 TBI
Transmission: 200R4/ 4L60
win aldl
Anyone using windaldl?
I have it and for some reson it is not showing any sensor inputs... an help is appreciated.
Here is a screen shot of what it displayed today.
Old May 9, 2005 | 10:43 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Wow, you got it to hook up to your 1227165 ECU? That's farther than I've gotten. Which cable are you using?
FYI, probably get a better response out of the DIY Prom board...
Old May 9, 2005 | 07:55 PM
I made my cable. In my application I had to get the 12v from the car. Then I made the small circuit. The diagram for the connector layout is for the pc connector( from the front) and not the cable connector (from the front).
Old May 9, 2005 | 07:59 PM
I just added this psot to the DFI and ECM section...
Please reply there.
THANKS!!!
Old May 9, 2005 | 08:22 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
1) Have you used the cable before with good results?
Old May 12, 2005 | 09:20 PM
no I just constructed everything and have never used it.....
this post has moved to:
https://www.thirdgen.org/techbb2/sho...hreadid=296702
Hotrodboba400
Dec 10, 2019 07:07 PM
Nervous2
Oct 8, 2015 10:53 PM
Angie Coots
Sep 23, 2015 07:42 AM
greenyone
Sep 8, 2015 08:41 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
