DFI and ECM Discuss all aspects of DFI (Digital Fuel Injection), ECMs (Electronic Control Module), scanners, and diagnostic equipment. Fine tune your Third Gen computer system for top performance.
winaldl
Old May 9, 2005 | 07:58 PM
lawrence_1md's Avatar
Car: 86 MonteSS/ 92 Camaro RS
Engine: 350 TPI / 305 TBI
Transmission: 200R4/ 4L60
winaldl
Anyone using windaldl?
I have it and for some reson it is not showing any sensor inputs... an help is appreciated.
Here is a screen shot of what it displayed the other day.
Old May 9, 2005 | 08:24 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
All that screen shows is that winALDL is not connected.
Double check the WinALDL configuration, port settings, the cable, ALDL terminals, and car must be in the "On" position or engine running.
Serial to USB (RS232) converters have caused issues for some, though I've never had any such problems.
Old May 9, 2005 | 11:21 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
What ALDL pin, "E", or "M?"
The manual states that the serial data is available at both pins, but "E" is a 160baud rate.
I tried Turbolink, and EFILive. The comm link fails on "E, or M" on both scanners, although my rs232 breakout box data led does flicker when the key is on.
I emailed Jonas at Winaldl about the data pin:
Hello Raul,
If you have an 88 TPI Camaro then yuo should have a pin on E.
You can try using M instead because I don't think you should have one there.
Perhaps a previous owner moved the pin.
Jonas
----- Original Message -----
To: <winaldl@joby.se>
Sent: Thursday, February 17, 2005 3:17 AM
> Under the vehicles supported section "PFI data streams" ECM 122165
> applications 1986-89 5.7 V8 PFI '8' L98 (of which mine is a 1988 5.7 V8
PFI
> '8' L98) it says "READ DATA ON PIN "E" OF ALDL CONNECTOR."
> I don't have a pin in the ALDL connector location "E," but I do have a pin
> "M." Does this mean I can't use WInALDL on my Camaro?
Old May 10, 2005 | 12:52 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
FWIW, I use pins A (ground) & E(data). I have a TBI car though and the '8746 ecm.
Old May 10, 2005 | 08:54 PM
The red light beside the word configuration was blinking and the ct was changing along with the proid... maybe I had a poor at the serial data line
Old May 12, 2005 | 09:17 PM
Okay I found something but have not tested it yet... For the 165 ecm it has to have a 10 ohm resistor jumpered across terminals A and B.... for the ECM to release the data. I know you collect the serial data from terminal E
Old May 12, 2005 | 11:16 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
FYI...from AllData database for 1988 IROCZ
ALDL Mode Description
The SCAN tool can be used in 3 different modes:
  1. The normal or open mode
  2. The 10K, special or ALDL mode
  3. The factory test, back-up or 3.9K mode
Most SCAN tools are programmed so that the system will enter the special (ALDL, 10K) mode directly, and the `normal' or `factory test' modes must be selected manually, if available.
In the special mode, all information incorporated into an engine/ECM combination is available. However, in the special mode engine operating characteristics are modified as follows:
  • The closed loop timers are bypassed
  • EST spark is at full advance
  • The IAC (if equipped) controls idle speed at 1000 RPM
  • The park/neutral restrict functions are disabled
  • And on some engines the canister purge solenoid is activated.
...the remaining terminals of the ALDL connector allow access to specific system circuit information. Terminals ``E'' or ``M,'' depending upon the application, allow for the connection of SCAN type testers in order to read serial data.
Although not all engine/ECM `families' are able to transmit information on the serial data line with the SCAN tool in the normal (open) mode, on engines that can be monitored in the open mode the SCAN tool allows data on certain operating parameters to be obtained without changing engine operating characteristics. Selecting the factory test or back-up mode causes the ECM to operate on the fuel back up logic programming, designed to allow system operation in the event of an ECM failure. While selection of this mode verifies that the back up programming is functioning properly, parameters that can be checked with the tool in this mode are of little value in diagnosing system malfunctions.
Old May 18, 2005 | 08:44 PM
yes!!! I got it working. It took the 10k ohm resitor for it to work.
Now I need to find out which one is the fuel trim...
Old May 18, 2005 | 08:46 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Right on ! . . one step closer.
The ECM corrections to your VE tables can be seen under BLM tab.
edit: perhaps I spoke too soon. This is not your TBI car.
Old May 18, 2005 | 09:34 PM
when I hit log data and save... where do I retrieve this info logged?
I wish there was write up for this program...
Do you know of any other program that uses the same cable?
Thanks!!!
Old May 19, 2005 | 12:48 AM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
If you installed to the default location C:\Program Files\WinALDL then you'll find your log files there. BLM, INT, and 02 as well but you save those indepentantly on each tab.
WinALDL is a great program and you really don't any other. Add a WB02 for WOT and fine tuning and you can't go wrong.
If you haven't already, read through all the stickies on the DIY PROM forum. They're full of insight for what your gonna be looking at.
Old May 22, 2005 | 07:39 PM
I will try to look for the info in the other topic section....
92blue
DIY PROM
Jul 18, 2002 09:52 AM
JoBy
DIY PROM
Apr 27, 2002 07:55 PM
JoBy
DIY PROM
Feb 9, 2002 06:08 PM
