fuel pump???
Old May 14, 2005 | 12:01 PM
305TA85's Avatar
Car: 85 T/A & 98 T/A
Engine: 305 tpi/ 5.7 LS1
Transmission: 700 r4/ T-56
Axle/Gears: 3.23/ 3.42
fuel pump???
I have a 1985 305tpi trans am automatic
it has full flomaster exhaust no cat or air headers k/ns accell coil and few other things. My car when stated cold immediately dies after 5 secs if i don't keep the gas up. I was wondering if any of you have this problem. I know al ot run really rough on the low but this wont run at all without help. started doing this right after i put the haders on. I found a couple busted plug wire, a lose spark plug. Fixed them. Ohh yeah just bought the car haven't been the mechanic on it fo to long. new manifold gasjets new fuel filter. The iac and tps were recently adjusted however i don't believe thi to be the problem. throuws the ses light once and while too
Old May 14, 2005 | 07:00 PM
formula1988's Avatar
Car: 1988 forumla 350
Engine: l98 350 tpi
Transmission: 700r4 2100 stall
My car did the same thing and I put in a new fuel filter and it didn't do it anymore.
You also need to correct your spelling alittle bit to make your post more readable. Not to be mean, but it took me a couple times reading it to understand it.
Old May 17, 2005 | 05:33 PM
305TA85's Avatar
Sorry for the confussing begining. It already has a new fuel filter. Iam going to adjust the tps and IAC vlave this weekend. Hopefully this will work.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
