86 vette PROM
Old May 14, 2005 | 10:47 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
86 vette PROM
Heys guys,
My neighbor just gave me a Prom from a 1986 Vette.
anyway, my car which Had a LB9 5.0L was taken out and fed to the dogs. My new setup .. a MAF L98 backed by a 700r4.
will this 86 MAF vette prom work with a 1989 TPI car?
I was intending to run my 350 with the 5.0 PROM,
instead I could pop the 86 vette prom in that is already dialed in for an L98.
I was told using the 5.0 prom would still run, but who knows how well it would run.
my guess is it would probally be tempermental
Old May 15, 2005 | 01:07 AM
rezinn's Avatar
Why not just get the correct PROM? I don't think it will work well if at all.
Old May 15, 2005 | 10:21 AM
Vader's Avatar
It should work, but you won't have a cold start routine, so startign may be a problem. There may be other issues as well.
A $6E ARAP-based *.bin is likely going to work best for you.
Old May 16, 2005 | 03:40 PM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
Running my MAF 355 with a TPI '87 305 PROM, correct 350 injectors/ESC, no cold start.
Cold start IS the worst issue, although there is a healthy off the line bog if it's floored. Mileage seems to be less than optimum too.
Trick I found for cold start is to crank the engine for a split second, then crank it like normal immediately after. Essentially adding a bit of fuel. Starts much easier like that.
Correct PROM is upcoming, I've got the tools to burn them now, it's the "right" fix.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
FormulasOnly
Jul 23, 2018 08:47 AM
dusterbd
Sep 29, 2015 08:40 AM
Winchester1094
Sep 15, 2015 09:48 AM
