Rough Idle/Surge/3 second start?
Old May 16, 2005 | 11:57 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Hey
I recently bought a 87 GTA L98. A week later, the ****ty accell wires burnt up on the headers - and they had heat sleeving over them.
They are edelbrock headers, which the air tubes are in the way of routing the wires. The Car has no air system, so I cut the tubes off the headers and welded them.
I also replaced Cap, Rotor, and the wires with MSD Super conductors.
The major misfire is gone. There is a slight misfire and 50rpm - 100rpm surge.The car vibrates when you bring the idle up to say - 2000rpm.
I can not feel the misfire under load.
Also, the car takes about 3 seconds to start, which I beleive is related to this issue.
I was testing the spark from the coil pack and it was good. After I pluged the coil wire back in, I noticed the car started up right away. Switched it off, then tried to start it and it took the usual 3 seconds.
Tried it again, looks like getting fuel into the cylinders makes it start up instantly.
Ideas?
FPR?
Injectors?
Pump?
I replaced the fuel filter a few days ago.
Old May 19, 2005 | 05:44 PM
Vader's Avatar
What is the standing fuel pressure?
Old May 19, 2005 | 08:00 PM
I'm going to go buy a gauge tonight.
Old May 21, 2005 | 02:57 PM
87camaro kid's Avatar
Car: 1987 Z28
im intrested in the cause of that because im having the same exact problems with my car on my knewly built motor...did u find out what was causing that?
i was thinking of geting the msd ingniton to see if that would fix it
Old Jun 3, 2005 | 03:00 PM
J Dahl's Avatar
Car: 1989 Firebird Formula
Engine: 5.0L TPI
Transmission: AT
thats nothing. my 89 Formula takes 3 times to start! The first it just cranks, the second it crankes and surges and stalls, and if I am lucky, the 3rd try it will start but not without the help of me pumping the gas!
but it runs great after that, so whatever. It has a 150K miles on it.
Jon
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
