What engine do I have?
Old May 17, 2005 | 11:30 AM
ktacam's Avatar
Car: 85 z28
Engine: 305 tpi (I got screwed, supposed 350)
Transmission: 700r4, b&m shiftkit
The engine is supposed to be an 89 350 but I can find not casting marks. It has perimeter valve covers, tpi, air, and a serpentine system. The sides of block are cast 627. The car was originally a 305. Anyone?
Old May 21, 2005 | 12:46 PM
Vader's Avatar
Take a closer look at the left rear ledge on the block:
Refer to www.mortec.com for a definition of the casting numbers.
Old May 23, 2005 | 10:52 PM
formulajokester's Avatar
Car: 91 gta
Engine: 350 tpi
Transmission: auto
I think any engine with the casting 627 on the side is a 350. A 636 designates a 305 I believe. If it is an 89 it should have a 5.7 stamped into the ledge shown in the pic above.
Old May 24, 2005 | 08:45 AM
sittincamaro's Avatar
Engine: IVTEC 2.4L aka SBC
Transmission: auto
anyone have any info about the 69 302 blocks?
Old May 26, 2005 | 04:54 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
perimeter valve covers i thought 87+ had centerbolt?
Old May 26, 2005 | 07:22 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
69 302 Z28 block will have a DZ stamp on the block (passenger side front below cylinder head) its a 3/4 inch wide ledge....
Old May 26, 2005 | 05:34 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Yes, but the heads would work on most any SBC. So that wouldn't tell if the block was stock or not.
Just get the cast numbers like in the pic above, it will save lots of time and guessing.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
