Misfire - Worse when engine is hot?
Old May 26, 2005 | 08:47 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Heres the deal;
Car has a misfire that I can feel when in neutral/park. I cant distinguish it as much when it is under load.
When you listen to the exhaust by the tailpipe, you can hear the misfire about 1 time in 3 seconds when the car is cold.
When the car is hot (to the point where the fans kick in) you can hear it much more - maybe 3-4 times in 3 seconds. Its randomly misfiring. It will go misfire good good misfire misfire good misfire good good good misfire misfire good misfire. Etc etc. You get the idea.
Fuel injectors were cleaned/flowbenched etc in 2000 or so. The guy I bought it from was in the same car club thinger. He has drove it maybe 12,000km since then.
Tested fuel pressure:
Key on: 46psi held for long time
Engine running: 38 psi steady
Reving: PSI goes up accordingly
Injectors: All of them are at 16-17ohms resistance. The selenoid fires on them all.
Replaced: Cap/Rotor/Wires/Plugs/O2 sensor.
No Codes.
TPS works good.
IAC seems to work good.
IDeas?
The engine only has 85,000 miles on it (140,000 km).
Ignition module?
Old May 26, 2005 | 08:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Try the ignition module.
Old May 26, 2005 | 08:59 PM
How much do they run?
I Get Trade cost on parts at Napa and a few other places.
Old May 26, 2005 | 09:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No idea, I've never bought an HEI module.
theshackle
Mar 5, 2017 06:37 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
