Got a question about the power I'm making..
Old May 17, 2005 | 10:31 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
Hey guys i'm new to this forum, I'm usually on camaroz28.com but since i heard about this, ill be spending alot more time here heh. Anyway I have a 1992 Camaro 350 TPI with the following specs..
Comp Cams Roller Cam - 224I,230E @.50/
.513"I,.520"E
Comp Cams roller tipped rockers (1.52:1)
Comp Cams 1.437 dia duel valve springs
Comp Cams locks, retainers and 11/32 teflon seals
Holley Twin 58mm throttle body
Gasket matched intake ports, and throttle body body ports
Heads resurfaced and machined to accept cam hardware
Port and polish job
Heddman 1 5/8" shorty headers with Y pipe
Catback exhaust
Underdrive pullies
K&N filters
MSD 8mm wires
Accel 300+ digital ignition
Hypertech Stage 2 chip
160 degree thermo, 176 degree on/166 degree off fan switch
3.73 gears
Accel 30# injectors with adjustable fuel pressure regulator
Corvette Servo
Transgo Shift kit
Right now the engine is being rebuilt (bored .30 over etc) and im reusing my heads, cam and intake. Now i know that the intake and heads on this car arent the greatest,and that the cam is alittle big for my stock heads, but the car needs alot of work and I couldnt blow it all on the motor alone. Ok so my question is what hp/torque will i expect to see from this combination? id like to get a rough estimate to see if I want to make any changes before final assembly. I'm hoping for 350 flywheel hp...but you guys will know better then me, so what do you guys think?
Old May 17, 2005 | 10:47 PM
Guest
Guest
Posts: n/a
Its possible to hit 350 on a good tune with that setup, depending on how good the heads and intake really are.
I was at 280ish at the rear on a somewhat similar setup, picked up some more with tuning and minor mods, probably another 20-30hp.
Old May 17, 2005 | 10:59 PM
Car: 1991 Z28
Engine: SBC
yea i plan on ditching the hypertech and getting a custom chip and tune by diablo performance around here.
Old May 17, 2005 | 11:09 PM
Car: 1991 Z28
Engine: SBC
anybody else got an opinion....i really wanna know the torque too...since the tpi makes such awesome torque
Old May 18, 2005 | 08:42 AM
brutalform's Avatar
Welcome aboard! Your combination looks great, except for one thing, the Hypertech chip. With the S/D system, you will definately have to tune that to get the best results, and power. Does Diablo tune on the fly, or are they going to guess? Ever considering taking a look at the DIY Prom board? I believe you will make the numbers you are after. And even MORE with a properly tuned eprom.
Old May 18, 2005 | 11:33 AM
Car: 1991 Z28
Engine: SBC
I HEARD, now im not too sure, that they take the car, dyno it, tune it with a new custom chip according to my specs, then dyno it again and try to make the most power.
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bert87
Aug 23, 2015 03:50 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
