How to fix rough idling engine?
Old May 18, 2005 | 01:15 AM
Meatwad's Avatar
On Probation
Car: 1987 IROC
Engine: 350?
Transmission: 700-R4
My motor idles at 900rpm but is really rich and ugly sounding....it just has trouble and dies sometimes....is there anyway to fix this easily? I have checked TPS and it was right on?
Thank you,
Meatwad
Old May 19, 2005 | 09:46 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Check O2 sensor and spark plugs. They should give you a clue.
Old May 20, 2005 | 08:41 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Did you set minimum airflow? I did this on my car with an idle problem and it helped. Also the IAC is worth checking out as well.
have any vacuum leaks?? just some ideas hope it helps
Old May 20, 2005 | 09:04 PM
iroc&harley's Avatar
i had same problem turned out it was IAC borrowed one off friends car to check
Spyder_TheGamer
Dec 25, 2015 05:07 PM
86IROC112
Aug 17, 2015 02:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Bradsaundry
Aug 12, 2015 12:34 AM
