305=350 ecm
Old May 24, 2005 | 09:46 AM
Calico's Avatar
Car: 1985 Buick Regal T
Engine: 87 3.8 turbo/lc2 drive train
Transmission: 200r4brf
305=350 ecm
are the 305TPI and 350TPI ecm interchangeable? Blackrob91 called advanced auto for a 350 ecm because he thinks his car still has the 305 ecm in it from when the guy before him swapped the motor to a 350! IF it does what problems would this cause? And how can we figur out if he has a 350 ecm or a 305?
Old May 24, 2005 | 10:27 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
ECM is the same as long as we're talking MAF to MAF or SD to SD.
MAF from '86-89 used the '165 and SD frmo '90-92 used the '730.
Chances are if he was able to plug in his harness into the ECM, he has the correct one.
The EPROMs/MEMCALs (chips) are different though.
Old May 24, 2005 | 10:35 AM
Calico's Avatar
how would he check his prom? would it be a better idea to just get a chip or something?
Old May 24, 2005 | 10:46 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
He'll need to pull it out and check the numbers on it, then search or post up, someone will probably have the answer as to wheter it's a 305 or 350 chip. If it's a GM chip, he can just call the dealer for info. If it's after market, he'll need to call the manufacturer.
Jake_92RS
Jan 28, 2020 10:37 PM
Jae992
Aug 27, 2015 09:07 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
marcusaw
Aug 10, 2015 08:13 AM
