Lt1 Intake
Old May 25, 2005 | 05:32 PM
305TA85's Avatar
Car: 85 T/A & 98 T/A
Engine: 305 tpi/ 5.7 LS1
Transmission: 700 r4/ T-56
Axle/Gears: 3.23/ 3.42
Lt1 Intake
I have a 85 trans am, with a 305 tpi. I am machining a lt1 intake for my friend currently. I am thinking about putting one on my car as well. I have a coil in cap distributor. Correct me if I am wrong, but you need an externally mounted coil for clearance on the intake. What does it take to switch from each distributor. Thanks for any help.
Old May 26, 2005 | 11:42 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
You can usually find this info with a search or a visit to John's website I believe... http://www.lt1intake.com/
All it takes is a pigtail wire set from a small cap electronic HEI ('87+ V8 F-bodies, many trucks, etc with V8 too) and an '87+ small cap distributor. Wire it up using wiring diagrams to match up the wires between each distributor... I think someone actually makes a distributor harness adapter too to eliminate the rewiring work.
Or, if you have aluminum welding ability, you can grind clearance away for the large cap HEI and just patch up the holes in the EGR ports in the intake.
Old May 27, 2005 | 01:41 PM
305TA85's Avatar
I am looking for the hei swap information and he does not have than info, but will I be able to grind away the manifold and reweld to make mine fit. Does anyone know where to find the conversion?
Old May 27, 2005 | 07:01 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
before
Old May 27, 2005 | 07:02 PM
91banditt2's Avatar
Engine: 5.7 HSR
after
Old May 29, 2005 | 10:47 AM
305TA85's Avatar
Cool, thanks for the picture. Do you have any dimensions.
Old May 29, 2005 | 10:54 PM
91banditt2's Avatar
Engine: 5.7 HSR
for what?
Old May 30, 2005 | 10:46 PM
305TA85's Avatar
I was curious how far to cut the egr ports back, to make the distributor fit.
New2Chevy
Sep 28, 2015 12:35 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
toronto formula
Sep 10, 2015 07:31 AM
L0tuS
Sep 4, 2015 11:16 PM
