Injector compatibility ??
Old May 26, 2005 | 11:16 AM
MiikeS's Avatar
Quick question from a TPI newbie:
Are there any issues with using LT1 injectors in an '87 TPI system? I thought I read somewhere that they might not be completely compatible but I can't remember where I saw that.
Old May 26, 2005 | 11:28 AM
Wayne's 383Iroc's Avatar
Car: 88 IROC
Engine: 383
We used a set of 24# LT1s in my frinds 88' 383, and I have the LS1s in mine. They should work fine as long as the prom is programed for the higher flow rate.
Old May 26, 2005 | 11:54 AM
MiikeS's Avatar
Thanks for the info. I've got a line on a set of 24# LT1 injectors for my 350 and just wanted to make sure I wouldn't have a problem.
On a related topic: I need a recommedation for someplace to get my prom programmed for my specifics. I'm sticking with the MAF so I should have some wiggle room, but the computer I've got is from a 305 so I'd at least like to tell it I've got a 350 (0.06 over) with 24#.
Old May 26, 2005 | 12:40 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Without chip reprogramming, how would the car run??
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
