What is this Thing on Plenum?
Old May 31, 2005 | 11:41 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
what are the vacuum lines to in the pic and also what is the thing bolted to the plenum to the right of the lines? is this an egr thing?
Old May 31, 2005 | 11:45 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
that is the map sensor, instead of using a maf to measure the air, it uses manifold vacuum to measure the load of the engine.
Old May 31, 2005 | 11:47 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
ahhh, awesome. thanks, are those vacuum lines associated with the map sensor or the egr. im mainly curious of the cylinder between the lines, what is it?
Old Jun 1, 2005 | 01:07 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The small black thingy is some sort of check valve. Someone asked this same question lately and I believe that RB83L69 posted a great answer, but I can not find the post.
The soft vacuum line eventually goes to the cruise control diaphragm. The the hard plastic line I think goes to the vacuum accumulator for the HVAC system.
Old Jun 1, 2005 | 06:40 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
cool, well i guess ill find out for sure when i drop in the new motor but i was just pretty curious at the moment
Old Jun 1, 2005 | 08:29 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
That vacuum thing is a check valve.
Engine vacuum is on one side (connected to the plenum). The two lines on the other side of the valve go to the HVAC controls and the cruise control (if so equiped). There should also be a vacuum reservior on this side of the valve.
This valve is there to maintain vacuum to the HVAC controls, and cruise control under low enging vacuum conditions.
When engine vacuum drops, the check valve isolates the HVAC controls and the cruise control from the engine; vacuum is then provided by the vacuum reservoir.
MantyZ28
16
Dec 21, 2015 11:02 AM
Magman
29
Sep 12, 2015 10:41 PM
Thaney9
Aug 29, 2015 03:16 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
Bob88GTA
Aug 18, 2015 03:31 PM
