low vacuum?
Old Jun 5, 2005 | 01:06 PM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
low vacuum?
I hooked up a vacuum guage to my plenum yesterday and was reading a steady 12 Hg at idle.
Is this low? Isn't it supposed to be 17-20 Hg?
Old Jun 5, 2005 | 07:29 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
For a stock to mild cam it's low.
If you don't have a vacuum leak somwhere, could be the throttle blades are too far open at idle.
Old Jun 6, 2005 | 02:04 PM
Svelte_SS's Avatar
Engine: 5.7L TPI
So how do I fix that? Just re-adjust my minimum air?
Old Jun 6, 2005 | 07:15 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Yes, should set minimum air to spec...not to control idle. The IAC should control idle speed to target RPM once min air is set.
Old Jun 7, 2005 | 02:26 PM
Svelte_SS's Avatar
Engine: 5.7L TPI
so what should my vacuum be at idle?
Old Jun 7, 2005 | 03:37 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Stock motor at sealevel, should be 18+ in/hg.
db057
Apr 28, 2019 07:45 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
amcnellis
Sep 16, 2015 04:16 PM
adelane
Sep 9, 2015 08:51 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
