super ram
Old Jun 2, 2005 | 11:42 PM
slick's Avatar
super ram
hey there everybody.is the superam worth the money it seems pretty weak up top wuold a supercharger help that
Old Jun 5, 2005 | 07:47 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
SuperCharger would help anything. SR may be weak uptop compared to other intakes, but with the correct setup it's an 11second 350.
Also, it the best 50-state legal intake...if emissions is a concern.
Old Jun 6, 2005 | 12:39 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
It's also the ONLY emissions legal after market intake system....
Old Jun 6, 2005 | 07:37 AM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
I'm so glad Holley made an EGR version of the HSR.... NOT!
I will never understand why they didn't. "Hey guys, here's a great intake, but if you have to pass a NOx check, your screwed."
Old Jun 6, 2005 | 08:23 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Do your own tuning, it will let u help the NOC out real quick for passing :-)
Once u have that under control.... tack 2 studs to the side of the HSR and install fake egr valve :-)
Make sure tor un equally fake egr control solonoid.
Unless they ask for EO numbers your ok :-)
later
Jeremy
Old Jun 6, 2005 | 09:16 AM
GOY's Avatar
GOY
I'd hate it put my faith in that, then not be able to pass for whatever reason, and not drive the car due to expired tags....
Can you really tune out the EGR without using a high duration cam? Are you just dumping fuel into the motor too keep it cool?
Old Jun 6, 2005 | 07:19 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Couple thing...Accel also make runners and the SR base, Edlebrck too, that are 50-state legal...prbably a few more as well.
Re: the EGR mod...no good if you have to have a functional test...probably okay for sniffer-only. Unsure on the legalities though.
Old Jun 7, 2005 | 12:47 PM
GOY's Avatar
GOY
Edelbrocks base sucks, and LTR's are what I tihnk he's trying to stay away from (note him asking about hi rpm power)
Old Jun 7, 2005 | 03:39 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I agree, but didn't want anyone who read above about "the only" to be misled.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
no green
Jan 9, 2016 09:22 PM
mfp189
Sep 27, 2015 09:25 AM
Dragonsys
Sep 25, 2015 03:51 PM
