idle adjustments
Old Jun 9, 2005 | 01:03 PM
lesser85's Avatar
Car: 85 Z28
idle adjustments
Okay, I seem to have no luck getting my warm startup idle speed to come down. My car wants to rev up to around 1800 rpm @ startup and only drop down to 900-1000 in nuetral. My min idle speed is set to 400rpm in drive 450 in park. My tps is new and set perfectly. My SES light does not come on and no codes are present. Is there something I'm misssing? Are there any adjustments that can be performed on the IAC besides min idle speed?
Old Jun 9, 2005 | 01:45 PM
rsn932's Avatar
check for vacuum leaks
rsn932's Avatar
Old Jun 13, 2005 | 05:15 AM
dyeager353's Avatar
Car: many
Engine: many
Transmission: many
many things can be wrong. Have you driven the car yet? bad cts is another possibility.
Old Jun 14, 2005 | 01:03 PM
lesser85's Avatar
Car: 85 Z28
My CTS is brand new and I have no vacuum leaks
Old Jun 16, 2005 | 01:36 PM
lesser85's Avatar
Car: 85 Z28
Has anyone ever experienced what seems to be slow operation of the IAC. That would be the best way to describe my actual problem. Funny thing is, if I disconnect the under hood fuse for the ECU while the engine is running, when I re-install it and fire up the car it starts perfectly. This only lasts one or two engine starts however. Clearing the ECU does not help, I have tried it more time than I can count!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
